Food for thought
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=55752
Author:  Ken Nagy [ Mon Jul 10, 2023 6:32 pm ]
Post subject:  Food for thought
Especially for Electric builders.The 12 string head stock is nicely done.
https://youtu.be/4SzI4okAURg
Author:  Chris Pile [ Mon Jul 10, 2023 8:23 pm ]
Post subject:  Re: Food for thought
I've seen that headstock concept done before, but I can't recall when or where I saw it.
Author:  Barry Daniels [ Tue Jul 11, 2023 9:41 am ]
I think his work process order is bad. He should have laminated the body strips before cutting out and sanding the shape.
Author:  Ken Nagy [ Tue Jul 11, 2023 10:36 am ]
You could:
Laminate strips
Glue into a block
Saw out shape rough
Cut strips the other way
Laminate those.
Glue back together
Rout shape with pattern.
I don't see any way around cutting the glued up strips at least once. Laminating and gluing trapezoids would be a nightmare.
Any thoughts on the scarf joint being a narrow angle in the neck?
